Re: 1993 mercury 200 offshore tilt/trim sender?
thanks for the info, it has 2 small rams and one big ram in the center, i still cant find a sensor or even a mount for it, on the port side there is a lever to support the motor. also is the tilt/trim switcha sealed switch? i was out today an it was a little rough and was getting some spray. the motor tilted up all by itself. the tilt/trim switch on the cowling got wet and made connection and tilted the motor up when i was running.
