New to the forum but hopefully the my details will be right to the point. Ignition switch is out on my 1980 Mercury 80 horse outboard. The serial is in the 480'000 range if i remember correctly with no power trim. I have referenced it in the past and it is a 1980. It uses a Mercury Quick silver controller with a auto choke (ignition key switch depression to engage) key switch. This has become the faulty component in starting the boat. I am currently seeking a replacement but I am seeking a wiring schematic for this switch. It has six pins and I understand some of the color codes (choke solenoid, neutral switch) but not all of them. If any one has this along with an appropriate engine wiring schematic I would greatly appreciate it.
Thanks for your time
