I was hoping someone could verify that my problem is most likely the need for having my carbs rebuilt. The engine is hard to start and usually takes quite some time of cranking and cranking with the fast idle set to max before it will fire up and even then it will keep dying sometimes unless I push the key in to choke engine repeatedly as its stalling. If it does get up and running it will run just fine the whole time until I turn it off. There is also fuel leaking somewhere behind the carbs and I dont know if this is from over priming the bulb or what, but it does leak some especially on this one spring/screw object near back underside of carb ( I will post picture pointing to it) I would just like to know if this is most likely signs of needing my carbs rebuilt or something else. There was enough fuel one night that the gas trickle actually caught on fire outside the motor and I had to quickly throw water on it to put it out. I saw what was either fire pops from carbs or electrical sparking. I check for electrical sparks by spraying soapy water on everything while it was running the next day and didnt find any electrical sparks, so I assume I was seeping flame pops from the carbs which ignited fuel drips that night? I have already checked spark at plug using a spark tester and it jumps a nice gap with blue spark. Thanks for any help anybody can offer in this situation. I will post a picture (specifically pic 4) showing where the main drip is seen. Thanks for all your help!
http://s1182.photobucket.com/albums/x458/darkwang/MERCURY%20CLASSIC%2050/
