Anybody have a picture of this model flywheel? Mine are no longer bonded to the cast iron and are causing an ignition issue on my motor:
Mercury Alternator Driven Ignition Systems
Two Cylinder Engines
NOTE: These engines sometimes develop a problem where you only have one cylinder firing. This can be caused by the flywheel magnets coming loose and shifting around until they touch. If only one cylinder is firing, remove the flywheel and check the magnets to see if they are tightly bonded.
Thanks - John
Thanks - John
