90 hp Force..... When motor is cold the only way to get it cranked is when trimmed all the way up (90-95%).... Why is this? Carberator issue? Repair ideas?
Leaking any fuel out of your carbs when trimmed up? If so, your floats aren't shutting off your float valve in the carb and the engine is flooding when positioned other than where the excess fuel can run out.
