Groupergulper
- Aug 21, 2009
- 73
i recently purchased a 93 Robalo with a 93 mercury 200 offshore only used in freshwater. On muffs (i know) It was not pumping water out the telltale stream. so i replaced the water pump, and now it pumps water out but at idle it takes about 10 seconds and it streams out kinda erratic. at higher rpm it streams out fine, is this a common thing or????
