Chris Breeding
- Jul 19, 2012
- 1
I have replaced high pressure fuel pump, primer bulb and fuel lines all the way to filter. Boat randomly idles above 800 up to 1600. this makes it hard to shift. Last time on water, same condition started shortly after running. also when I would hit the trim button, engine would stall like lost all electric fire, and most recently begins misfiring above 3000 rpm, but smooths out if below 3000. I tore into it last night and found loose crimp in trim circuit. Could loose connection here cause my other issues. I hate to keep putting in shop and not fixing problem, as well as replacing parts that may not need replaced. Any help would be appreciated.
