hey guys i have a 1996 mercury 2 stroke 115hp oil injected outboard. I recently noticed that when i am driving at low speeds the motor will not trim up. If i am able to trim it slightly it slowly falls back down. When driving very slow or in neutral it trims just fine. It also works when driving at top speeds. I spoke on the phone with a mechanic and he is saying that basically the whole unit has do be replaced. He says that the seals and cylinder id shot and cant handle the pressure of the wake at low speeds. It would cost be $1200-$1500 to fix. Does this sound right or does anyone have any other ideas. I was hoping i just needed to add some hydraulic fluid but i guess i was wrong.:facepalm:
