I recently replaced an older Johnson 150 with a 1997 Mariner and I seem to be having trouble starting it. I had the carbs rebuild and the Marina said that it runs fine but every time I try to start it I have problems and at this point I think it is the way I am starting it. What the sequence I should follow when starting?
Engine cold:
- pump bulb
- give it some throttle
- choke
- Start
It seems when i do this it floods and because it is oil injected it take a while to start and when I do get it to start I smoke out the area...
Am I doing something wrong or is there an issue with the motor?
Thanks in advance
Engine cold:
- pump bulb
- choke
- Start
Thanks in advance
