Sidhewynder
- Dec 15, 2010
- 17
Hi. Years ago I purchased an older boat that had been sitting for some time with a Mercury 50HP (500) outboard. Serial # 4286099. If my searches are correct, that makes it a 1975 model. The boat sat in my backyard for a long time awaiting free time; recently I got that time. When I purchased the boat, the motor would go into drive (prop ratchets in one direction, locks in the other), but I had to pull the shift lever back past the neutral detaunt into the reverse area to get neutral (prop spins freely both directions) and pulling the control lever clear back would barely pull the drive into reverse (prop spins in both directions with a clicking sound each way). I thought that the cables just needed adjusted and given the price of the boat/motor and the fact I wanted to learn about outboards, I drug the boat home.
Yesterday I removed the lower unit to replace the water pump impeller. I put the drive in forward and pulled the lower unit. When the lower unit came out, several pieces fell out. The water tube, exhaust tube and two plastic pieces from the front dropped on the ground. I have an older style lower end with a pre-load pin on the drive shaft. After replacing the impeller and much gnashing and grinding of teeth, I got the lower unit re-installed ? only to discover the motor was locked in forward. Long story short ? after uninstalling and installing the lower unit (and putting those two plastic pieces that fell out in the front in various configurations), I?m left with a motor that has forward, neutral past the detaunt in the control box and reverse that ratchets in both directions. Exactly where I started- just with a new water pump impeller.
The lower unit is the older style with a square shaft assembly whic slides into a square tube in the motor leg that rotates and selects the gears. Through trial and error, I discovered that shaft in the lower unit can rotate in either direction before engaging the gears (which gives the added bonus of being able to install it exactly backwards ? ask how I learned that little fact). After getting nowhere I took the lower unit back off and using a wrench to move the square shaft I can get a solid forward, completely free neutral and solid reverse (locked in both directions). With the motor in forward, I reinstalled the lower unit and disconnected the control cables, I worked the gear selector mechanism with a screw-driver where the cable connects. Looking at the slide where the control cable connects, if the slide is all the way front, I have a solid forward. As you push the slide towards the back of the motor it slips into neutral (about half to 2/3 of the way back the slide rail). When I move the slide clear to the back of the rail and keep a constant pressure on the slide traveler, I get a ?better? reverse (more ratcheting/catching) but still not solid like when the lower unit is off. There isn?t any adjust on the arm that connects the slide to a bellcrank (which is connected to that square tube that runs down the motor leg to the gear selecting rod in the lower unit).
So.. help! Does the prop on these motors really not lock solid both ways in reverse? Do I have the ?best? reverse I?m going to get? If they do lock both ways in reverse, how do I adjust I adjust things to get a more solid reverse? Have I just managed to move that gear selecting shaft into the wrong position? There?s a lot of play in that shaft. I think I have that plastic reverse locking cone in the correct position because the whole motor will pivot up when the selector is in forward, but locks when put in reverse (well, what little reverse I seem to have).
While you?re reading this, what is the proper or best way to adjust the control cables?
Apologies for the long post, I just don?t know the technical terms of the components, so I had to describe what they did.
THANKS in advance!!
THANKS in advance!!
