duckduckgoose
- Jul 7, 2012
- 2
I have a 1970 Mercury 50 hp that I have recently done some work on but I do not know where I have gone wrong when putting back together.
My problem being when I put into forward gear the boat does move forward but it only has what appears to be reverse speed. When moved into reverse it will go into reverse but it has forward power. The prop moves in the what I believe is correct clockwise position in forward.
I have done the following recently:
Replaced impeller, a shifter cable, and a shift lever in the control box.
I am confused, is the problem with the lower unit, the cables reversed, or did I mess something up in the control box.
I purchased this boat/motor needing repairs but the engine looks clean and the lower unit looks recently redone.
Thanks for any input, this seems to be the place.
