Leonard Ray
- Mar 9, 2010
- 69
I have an 1986 Mariner Magnum 150hp that does not start good.When it does start you have to to give it some gas or it will shut off and it will not run at all when you put it in the water.I have rebuilt everything but the reed valves.I can hold the intake up to the light and some of the valves are not all the way closed.I don't think that is good,am I right in saying they need to be replaced? should there be stops for the valves?
