I have a 1981 115hp mercury outboard motor... ever since I bought it a couple months ago, I have been having troubles with it running, and going into gear.... it seems to start ok but every time I put it in gear it stalls, I have to push the throttle way up(while running) and then back it off to get it to go anywhere...? Once it?s moving in gear it runs real smooth and pretty responsive...? I ran a can of sea foam through it and that did nothing but foul out the plugs, I cleaned out the carbs, and still doing the same thing... what?s causing it to kill every time I put it in gear????
