honda460ex
- May 12, 2011
- 69
Any opinions on this? I know gauges can vary, but I only have one gauge and it reads 120psi on cylinders 1,3,4,5,6. However cylinder #2 is reading around or just shy of 100psi. The motor acted up a couple weeks ago on the lake while running on plane and dropped around 1,000rpms. When I did come off plane it didn't want to go back up on plane and acted very weak and sluggish. Mechanic looked at it and said the coil was very weak on cylinder 5. Replaced the coil, wires, and plugs. Idles a little better but still doesn't want to come up on plane. I don't have a spark tester like the mechanic did so I really can't check to see if the spark is any stronger compared to the other cylinders, but all cylinders do have spark. Trying to test it by myself and not get jolted when checking each cylinder ='s no fun. Did a test on the trigger and it seems to be in specs for all cylinders. I have myself so frustrated and confused from thinking on it so much I don't know which direction to go. I have thought vacuum leak, power pack, or low-compression. But is that compression low enough to hurt me when compared to the other five?
