My 1977 Mercury 1500 is hard to start and is starving for fuel at half throttle. They only way to get it to start when it?s cold is to squirt some fuel into the carbs or choke it with your hand. The flapper chokes on the top two carbs don't seal good enough to pull any fuel into the carbs. I have rebuilt the fuel pump, replaced all fuel lines including primer, and cleaned the carburetors. I had the boat out yesterday and it will go to about half throttle then lose power and almost die. I noticed that the primer bulb was sucked almost flat. You could however pump it a little bit and it would pick right up but then would starve again. I removed the fuel cap hoping it wasn't venting good but it didn't help. I do remember that when I got the boat out this year the old primer bulb would pump once then stay flat so I replaced it. I also had an extra brass connector that screws into the top of the tank and it allowed the primer to pump up better. Does the brass connector have anything to do with venting? One other thing I should mention is that when I had the carbs apart I noticed that the float needle valve would stick shut when you pushed up on the lever. If you tap the top of the carb it would open back up. Is this normal, does the fuel pump have enough pressure to push the needle valve back open. I may have to break down and rebuild the carbs. I also tested the fuel pump by letting it suck straight out of a bucket and it has tons of flow. I may try to prime it up then stick the fuel line straight into the tank to see if that cures the problem. I have my suspicions that the primer or brass fitting is restricting flow.
Thanks in advance for your help.
