I took my boat to the lake last weekend, and it ran fine started every time I hit the key. today it had a starter problem. when I turn the key the starter turns but wont stop even when the key is turned off, had to remove the ground cable from solenoid to stop starter. I took the key switch out of the dash and unplugged it. then tried to attach the ground cable to the solenoid again, and with the key switch removed the starter tried to turn and I pulled the cable away to stop it. whats my problem, a bad solenoid would be my guess. does any of you guys know for sure with what I have said? thanks in advance for any info.
