TampaNate77
- Jun 6, 2012
- 117
So I bought the this motor few days ago... bolted it up and went to start it before completely bolting the control box and running the cables thru. So I check for spark and make sure its getting fuel before trying to start.... and its getting spark, but noticed that there is some fuel leaking coming from the fuel lines running to the valve assembly... there is like 2 valve type assembly's that the fuel lines are running into... well its leaking out of those lines. And so I went to try to start it just to make sure the motor runs, and spins, and spins, and spins but doesnt fire up. Then I hear some weird noise coming from the battery so I went to make sure the terminals were tight, and the Negative terminal was so hot it burnt my finger pretty bad. What the hell would cause that? I also notice the motor was in gear when I went to crank it. (throttle and gear cable are not connected yet)
