oldmerc150
- Jun 29, 2012
- 12
Hi all, this is my first post. I have been working problems out of a used 150v6 i recently purchased.
The s/n on the lower end is a 1979 but the power head has been replaced so i can't tell what year it is.
Now to the problem, the guy I purchased the motor from said it needed a new water pump because he didn't have a full telltale stream at idle. I replaced the water pump and still only get a dribble. I checked the thermostats be heating water on the stove and they were fully open at 145'. I installed a pressure gauge in the 1/2" plug on top of the motor and I was shocked to see 15lbs at idle. From what I have read it should only be 2-4lbs at idle and around 15 at full speed. The dealer told me if water is coming out of the center of the prop the water pump is working. At idle with muffs I get enough water to get your hand wet in a couple of seconds.
Thanks for your help
