Re: 1987 150 XR2 overhaul/rebuild
50:1 is actually 2.56 ounces oil to 1 gallon of gas 1st tank I doubled it up and put 5.12 ounces oil to one gallon of gas in to help lube while cylinder was breaking in on the first, second tank I halved that so I put 3.84 ounces oil to 1 gallon gas. I am running 50:1 now .
I shop I'm doubting will want to do what I did because they usually will do some sort of warranty. Also if they have to bore it out they pretty much have to tear the whole thing down to do it properly. I just honed the one cylinder after it failed I didn't bore it.
Being a mechanic myself in the auto field and it also being my boat and knowing how easy these motors are to break down I choose to do it the way I did.
Jim
