Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Why does my 1996 Mercury 115hp outboard use soooooo much fuel??
  • Why does my 1996 Mercury 115hp outboard use soooooo much fuel??
    First time boat owner... have taken my 18 foot baron out on the ocean... very smooth day... maybe 6km tops past Garden Island which is probably 12-14 miles from where we launched... we have used what I think is an incredible amount of fuel??? 60 -65 litres.... is this to be expected from a 1996 engine?? Averaged around 20 -25 knots cruising. Any ideas what could be causing this??? Any help will be appreciated.
    Re: Why does my 1996 Mercury 115hp outboard use soooooo much fuel??
    Welcome to the world of boating. 15 gallons for 40 or so miles. Sound pretty good.
    Get something black on the back.
    • #3
      How's the compression on the motor. Lower compression = higher fuel consumption because the cylinders do not hold fuel as well as when the are fresh. These motors are roughly 50% efficient when running good. It's just the nature of the beast.
      • #4
        As I recall the numbers, some "Big Guns on here" like to use the numbers 10% of the engine HP rating at WOT in GPH consumption. So, at WOT a 115 would use 11.5 gallons per hour. Soooo based upon the above numbers, you ran at a reduced speed but for 2 hours and consumed 15 gallons; 7.5 gallons per hour. Sounds about right to me.
        Mark
        If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
        • #5
          Mark
          Agree and for an older motor like this, that's not too bad at all.
          • #6
            Expect 2 to 5 mpg on a boat.
            • #7
              I think your fuel consumption numbers are great for an "old" 2-stroke.
              (I put "old" in quotes because to me a motor isn't really old unless it's older than I am )
              San Diego, CA "The 619"
              "Nemo" (since Jul 2004): 1978 StarCraft 15' TriStar, 1978-88 "FrankenMotor" Mercury 70
              Unnamed (since Dec 2016): 2000 Sea Hunt Triton 172 CC, 2014 Mercury OptiMax 125
              "It's always easier to ask forgiveness than permission" -Colin Powell, et.al.
              • #8
                depends too on how many POB you had,
                the baron is a fair size tub too,
                bit confused though...changing from K's to miles will do that..and l remember when we used imperial measurements,
                so you did around 27 k's one way and used 60-65 lts or did ~54 k's return on the same amount of fuel?
                my son has a 120 and will use that much pulling tubes and hooning around..
                of course, if you're in Sydney, the water is MUCH,MUCH harder to push through coz of all the "stuff" in it
                LOL
                happy little vegemite
