Grandpa Steve
- Jun 25, 2012
- 2
I need to pull the flywheel on my 1973 or 1974 20HP Mercury Outboard. In searching the internet I've seen a lot of problems with regards to not only marking the flywheel so that it goes back on in the same position but also questions on if the center bolt was removed. My questions that I need help with are below:
1. Do I need to remove the center bolt to take off the flywheel? It doesn't look like the flywheel will come off without removing the center bolt but I've seen comments that make me think that this isn't a good thing to do.
2. What is the best way to mark the flywheel to insure that it goes back on in the same position.
