Hello guys, I just bought a boat and all I've done is work on it so far. When I hook it up to a hose it idles and revs up good and goes into gear and revs up good. When I go to the lake and put it in gear and try to rev it up it dies! If I slowly rev it up it will stay running at low rpm's. I've check compression and all cylinders are good and replaced all the spark plugs. Ran fresh gas threw it with sea foam. Adjusted carbs back and forth. What else should I do? Any help would be appreciated. Jake
