geddron1976
- Jul 14, 2009
- 24
Re: PLEASE HELP ME BEFORE I GO INSANE!!!!!! 1986 Mercury 75hp 4cylinder idle trouble
Ok, i received the new shaft seals and installed the carbs back on to the engine. Followed the synch and link to the letter and guess what?
It still won't idle! I managed to tune it enough to get it to run smooth, but with the throttle valves completely closed, the idle speed was at 1900rpm?
Is there any way to bring the rpm's down? I have checked the whole setup out for air leaks and it's as airtight as a ducks ***.
i can only think that the timing is advanced too much, but bringing it down only seems to make the engine stall.
anyone got any fresh ideas as i am completely exhausted!
oh forgot to mention that it did run better with the seals and it doesn't leak fuel anymore. I also changed the fuel primer bulb just to be sure and it's all pressurizing ok now.
