geddron1976
- Jul 14, 2009
- 24
Hi All,
I bought my 75 merc around 4 years ago and it has been a great engine.
However, last season i began to get some problems with the engine not idling correctly. It began to be a little troublesome to start from cold and when warm, it would only idle for 2-3 minutes before dying out.
A quick rise of throttle would keep it going and give you about another 2 minutes of idle. It would stall at low speeds when manouvering on to moorings etc, as i transferred the gears from forward to reverse to slow the boat to a stop when aproaching the harbour wall and resulted in some bruising to the bow of my boat.
I decided earlier this year to service the carbs and bought a repair/service kit.
I stripped and cleaned the carbs and replaced all the parts that came in the kit and then consulted the SELOC manual to rebuild and re install the carbs. when the carbs had been installed, the engine would not run at idle at all!
It will fire up at fast idle on the control box with some choke, but as soon as the engine drops below 1800rpm, it just dies.
I had a friend crank the motor whilst i adjusted the idle mixture screws to see if i could get it to even cough, but nothing.
I have bought a timing light to check the timing advance but as the seloc manual states that the engine should be at idle speed and in forward gear in the water before the link and sync and timing adjustments can be made.
So, how can i make the adjustments if the engine won't idle? GRRRRRRrrrrr!!!
I am beginning to suspect a crankshaft seal, but that may just be my mind running wild due to the frustration of wearing out the cranking motor hoping for ignition before the battery drains again!
Is there anyone out there that can help me sort this motor out without having to get a mortgage out to do it?
I'd really appreciate the benefits of your guys experience and also if anyone knows the spark advance settings i woudl be grateful as i have been told that the SELOC manual is quoting BS.. i would love to get a genuine mercury manual for this motor but i can't find one anywhere.
Thanks in advance for any help youl can give me..
Best regards
Paul AKA Geddron1976
Best regards
