Re: Lower Unit
Thigh, If the prop rachets when turned CW, the motor is in neutral. If it wont turn either way, it is in reverse. Turn the shift shaft CCW if in forward or CW if in reverse. The gears will go into and stay in neutral. Set the control into neutral as well.
Grease the shift and driveshaft splines and insert the white plastic water tube extension into the water pump outlet. Slide the gearcase onto the midsection (tilt motor up all the way), turn the flywheel until the splines align. Now use a needle nose plier to align the upper shift shaft with the lower shift shaft.
