boatnut1978
- Mar 22, 2011
- 14
Motor has had alot of work done to it.
Carbs, fuleline, wire harness repaired, distributor housing.
It would start and run on the hose just fine, first put it in the water and it would not start or run.
I found that my timing was off very bad, fixed the timing problem. Put my idle at 4 and wot at 22...
No it will start and run in the water but the idle is too high. There is no adjustment left in the carbs to idle it down. And if I knock the timing down so far that it idles down to go in gear then it just runs like crap.
With timimg in normal position it is idling @1300-1500 rpms, and when you put it in gear it just dies everytime.
PLEASE HELP.
PLEASE HELP.
