minuteman62-64
- Apr 12, 2011
- 1,350
Got some water in lower unit issues w/1982 30 HP Mariner. Replaced the gaskets on the fill and vent screws and plan a run to see if there is still a problem. If there is, time for testing/remediation.
A couple of questions.
1. I've read a lot of posts that advise both pressure and vacuum testing to diagnose problems and verify an adequate repair. On my motor there are two seals on the driveshaft and two on the prop shaft. The flared/soft/sealing sides of all of the seals are positioned to the outside of the gearcase. To me that indicates that the primary function of the seals is to keep water out (as opposed to keeping oil in). So, in this case, wouldn't a vacuum test tell me all I need to know? IOW, why would I need a pressure test?
2. The seals are all original. If My test indicates a leak at one location (lets say drive shaft) wouldn't it make sense to replace all of them? As well as the boot over the shift shaft?
