I was out on the water trolling when out of no where the engine shuts off. Go to restart it and when i turn the key nothing happens, no click, no crank absolutely nothing. Had to get towed in.
I was looking over the motor today and noticed a couple things.
First, I am getting 12v to the positive side of the starter solenoid, and and when i turn the key i get 12v on the small yellow wire that also goes to the solenoid. Thats where the power stops. I get nothing anywhere after that. If i jump the solenoid the starter turns like normal.
Second, i pulled the wiring harness off the side of the motor, and when i did 2 of the male pins pulled out along with it. I jammed them back in and am still getting continuity through them, so i dont know how much of a problem this could be.
All in all i would just like to know if i need to replace the solenoid to get this thing started or if i am missing something else.
Also, the Choke button is not working anymore either.
Edit - Battery is brand new, all connections are bright and shiny.
Thanks
Thanks
