Hi- I'm wondering if my '73 mercury 500 is missing something. I haven't got this engine running yet but cannot see any way in which the gear linkage connects to the carbs'. I can see how you could 'open' the carbs' up by hand by way of the linkage between them but surely that linkage should go on to connect to the gear change linkage underneath?? Otherwise I cannot see how, when you put the engine in gear, the carbs can open up when they are ultimately controlled by the same cable. There is a small hole in the gear linkage underneath the carbs - is this missing something that links in to the carbs?????
Thanks in advance for any wisdom - please tell me I'm worrying about nothing!
