fishingman
- Oct 12, 2008
- 12
Hey everyone, I'm trying to figure out if my 1988 mercury 90 HP outboard has a bad seal in the hydraulics or a bad trim and tilt pump. I just picked up the motor, and know very little about it except its sat for last 3 years. Anyway, when I trim up, the motor wants to fall right back down. Once all the way up, the motor will fall down through the tilt and both trim cylinders in about 20-30 seconds. There are no external leaks and I checked the fluid level and manual release screw seals. I was talking to a local shop about the check valves going bad, but he said for it to fall through both the trim and tilt cylinders would mean all the check valves were bad and he thinks it more likely the pump. I removed the whole unit from the outboard and I am thinking about dropping it off at the shop, but I know that will get costly.
Anyway if there a way to diagnose if the trim and tilt motor and pump is bad? Its one of those eaton square pumps i believe. Or if anyone has any other idea's, I'd love to hear them. Thanks
