mickab
- Mar 5, 2012
- 53
hi all, just wanted to post a little helpful tip from my experience. if seen post on here talking about non voltage regulated outboards over charging and burning up sealed batteries. yes the battery acts like the regulator so with that in mind i run a optima yellow top battery as my cranking battery, which also runs my electronics. what i have found is if i charge this battery completely on the charger ill have reading of over 16 volt while im running the motor, but if i only charge it to about 80% i have zero issues. voltage never goes over 13.5 volts. as i fish bass tournaments every weekend ive had a lot of time to test my theory. but a good deep cycle with a lot of cold cranking amps is i think the key. i hope this helps my fellow mercury / mariner owners out their running this style of charging system.
