Re: mercontrol mystery component
Thanks again for replies. Gerry your knowledge of these outboards and all related bits is invaluable! On my mercontrol unit I would never have noticed the retention pin but for you. It was so seized I thought it was just part of the cast, however having managed to knock it out I found both springs intact, gave it a good dose of grease and put it back. It now works like a dream with a satisfying click! I now have new cables and fuel line connector + four decent sparks. When work load gives me time I hope it'll fire up and I don't have any carb' problems. I've read, in another thread, (possibly your reply!) that there can be a problem of float needles sticking if float chamber has been left full for any great length of time! Though 2I'd love the excuse to strip the carbs I now just want to see it run with maybe just a gear box oil change between now and putting it on the boat.
One last question perhaps you'd be kind enough to answer for me. The gear change mechanism should run on a small track with a plastic guide attached to the cable linkage. On my engine this plastic guide is broken off from the linkage. I could make a new one (and will do in the long term) but it is obviously a nightmare to get to. Will it cause me gear change problems without it , or more to the point will it damage the linkage, by putting strain on the wrong points, without it. As ever, your advice is much appreciated
Richard
