Hi everybody.
I have been attempting to read all of the information that I can regarding the subject of cleaning the carbs on my 100 merc. The boat had been struggling to run for some time and squeezing the fuel primer bulb helped. I don't know when the last time the carbs were cleaned, but following the advice of others who have had similar problems I have bought a gallon of the Berryman Chem Dip to use in cleaning (even though the manuals warn against it).
My questions come to WHAT I need for rebuild/replacement parts. I went to the Marina today and bought 3 gasket kits ($8 each) and 1 rebuild kit with gaskets/screws ($38) for the carbs. Do I need to buy rebuild kits for all of the carbs or can I just replace the gaskets??
Also when it comes to using the Berryman's chem dip stuff, can someone who has used it give me a quick run down of how to go about it? Did you take the entire carb apart or leave some pieces assembled when you dipped it? How long did you dip the parts for?
I am also planning on rebuilding the fuel pump too... Any thoughts?
Any advice would be appreciated!
bryman04
bryman04
