First off I ran the boat yesterday with muffs on it, started fine 3 times with no issues. Went out to the lake today and had a buddy driving the boat. Backed it in, started fine, then he put it in reverse and it died. Other attempts to start failed after that (i was still in the truck). We put 2 new batteries in it today and replaced/checked all fuses. Upon further investigation the starter is engaging the flywheel and clicking.. not spinning the motor over and the bendix will not disengage from the fly wheel. Never had this issue before. I dont have a volt meter handy to check the voltage on the starter solenoid... but should this be the first thing I check, or does it sound like the starter is done. Thank you, Jason
