This engine has been running excellent for a few seasons now. Wanted to do a test run before takeing it out a few weeks ago and it ran just perfectly. Then I went to full throttle for a few seconds and noticed the boot hose came off so after I put that on I tried it again, went to full throttle for about 10 seconds and then it made a sound like it missed. The one mistake that I made was that the gas only had half the oil that it should have had. After that happened its having trouble starting and its dieing out in idle. The main reason is because there isn't enough gas in the line but I'm wondering what could cause this other than the hose or gas tank?
I took it out today and it will run fine just above trolling speed and at full throttle. Could I have fouled a plug when I was running it at home with the wrong gas mixture and would that have anything to do with this problem? My question is why is it running out of gas at idel, trolling speed and when I try to start it after it has been sitting for over 1/2 hour on the water? I'm planning on changing the plugs but I'm just wondering what else I can check? S/N 6578665
