I have a 2007 Mercury 50 hp outboard, 2 stroke, not Bigfoot , and I just realized that I have to mix oil with the gas. The ratio is 50:1, my question is, how to mix them? Should I just pour oil into the gas tank?
The engine does have a oil tank(about 3 liters), does it mix with gas automatically ? If not, should I change it every once a while as regular maintainence?
Thank you!
Thank you!
