Re: 2007 Mercury Optimax Trim Problem
Sorry, it is actually a 200hp. Don't know if the problem is the same with this size motor. Thanks for the reply.
well, per generic mercury/oildyne hydralics
check your manual release valve. it should have three orings and a knobby little tip. If that is good then .....
if you lift to end of trim pistons but don't have the juice to lift tilt ram then it is probably a pesssure problem from pump. The trim rams need very little PSI to lift a dry engine. The tilt ram needs a lot of PSI. when pumps first go out they usually have a drop in PSI. Often trim lifts and holds but tilt does not.
If the system does not lift at all then the question is if it holds. Once you lift it, does it hold or drift down? If it holds then pump probably pump. Piston failures usually aren't spring loaded and bleed off from any angle. If the system simply does not lift and hold any angle under any circumstance then it could be a blown seal anywhere in any piston or pump.
