This is more of a parts question?
Also, this is my first post, so bear with me. Been trolling the forums/internet to find similar issues, but no luck.
I have a 1977 Mercury 850 Thunderbolt Ignition, 4 Cyl. 2-Stroke.
The original Tilt/Trim motor works fine, plenty of fluid.
BUT, my problem is when standing on ground looking at motor/transom. It's leaking from the cross-member underneath the right tilt cylinder. So, it's not leaking directly from the cylinder itself. It leaks from the cross-member or absorber (runs parallel to ground) that the cylinder goes into. I have no idea what this part is called it appears to be weathered underneath and needs to be refurbished or replaced.
If anyone has any idea of what I am talking about, advice on how to fix, a part name or needs more info. please let me know, it would be greatly appreciated.
regards
regards
