I have a merc 850 and its not peeing like it should, i assume something is clogged in the tube, because i took apart and replaced/cleaned the water pump. I also cleaned out the short tube the connects the block to the hole in the side of the motor housing. My question is does anyone have any advice on how to clean out the rest of the system to get it to pee like it should. Thanks
