incharleston
- Jan 30, 2010
- 9
I bought a lower unit for $100 from a guy that wasn't sure if anything was wrong other than seals leaking a little. Drained and filled ...all seems fine.
Looking at the two lower unit side by side they are nearly identical except this LU has a 3/8 inch longer driveshaft. I believe the difference lies in the fact the old LU has the preload type driveshaft with the pin on top (although mine is missing)
I have tried mounting the new LU but it won't go all the way. 3/8 inch short of mounting
Would it be OK to cut 3/8 inch off of the driveshaft?
