After replacing impeller and housing, I was surprised that motor was still not pumping water.
Tracing the hose back from the telltell, it runs into a housing that is divided in half by a diaphram, one half has gas going through, back half is supposed to have water going through. Continuing to trace I came to plasting hose fitting on the end of hose that had melted.... water was pumping out of the hose where this fitting screws into. Where can I find one of these threaded fittings? 10mm x 1.00, I have searched the internet and locally to no avail. Any help would be appreciated. Thanks!
jack
jack
