I rebuilt my carb today and after hooking everything back up, I discovered that I have a pretty bad fuel leak. Gas is leaking like crazy around where the new gasket makes contact with the gas inlet hose part. These pictures show the part that is on the carb:
I'm guessing the previous owner put this out gas attachment piece on as the one in the service manual shows a different piece than what I have:
What I need to know is if I should purchase a new part that doesn't leak, try reseating the gasket as that is where the leak is coming from, or what. I get an almost immediate bubbling of the gas and then leaking as soon as I attach the fuel line and pump the bulb. Also, does anyone have the actual name for that piece or a part #? The service manual doesn't have its name and I can't seem to find what it is called. Thanks for any help!
