Hi all,
Just picked up a old 12 ft aluminum boat with 6 hp Mercury. After doing basic diagnostics on the engine (checking spark, compression, fuel) I got it started relatively easy (considering it was sitting for quite some time). On a separate thread I was tailing I have a better understanding/feedback on what to expect with water flow (to ensure cooling) since water was coming out of the exhaust tail just not that much when idling. I did not know if that was normal. Thoughts?
Also, possibly gonna pull that flush valve/screw out and see if water comes out more smoothly. Again, tryin to set expectations since I don't want to burn it up. The engine appears to not have been used much and want to keep it for a long time. Other considerations include any regular/proactive maintenance suggestions. Changing lower gear oil is probably on the short list. Sorry if some of these are basic questions/items but, this is the first outboard I have ever owned.
Thanks in advance for your input
