Re: Water pump on Mercury 200HP 2-cycle
Check tell tale hole is not blocked with a piece of wire while running on hose.Not too sure on the 2003 model though flow usually gets stronger when engine warms and Tstats open....Having said that if you haven't changed impeller in 2 years or more...do it.
