I have a Mercury 50 hp ELPT 4 strokes , s/n 1C084939 Set 2008, recently change out the battery.
I hooked battery leads up to reverse poles.
I blew two fuses , the 15 Amps fuse (Main Relay/Accesories) and 25 Amps fuse (Main circuit). I replaced both , and correct the battery leads connection.
I have a problem , the 15 Amps fuse (Main Relay) blow , when I try to start the engine .
Power Trim works Okey.
Our Mercury dealer is 2000 km far , so I need solve this issue.
1- I disconnect all the boat accesories (Light, radio , pump, etc)
2- Battery voltage is 12.8 v
Thanks in advance for any help , I am a new to Iboats.
