1983ruston
- Mar 26, 2012
- 33
Anybody know what might have let go inside because she runs fine but shifter does not seem to be working.tia
Could be set screws. I'll send you the link to the parts list by PM. Apparently they don't like certain sites here.
Gerry
Gerry, I went to a site that offers the "set screws" which are shown in the parts diagram and seem to be a stocked part and inexpensive so it seems. Is this going to be a difficult service task to reach this part without a manual? Looking at the diagram, it looks like a lot of little parts before and after the "set screw"..I would like to know if there are specific/precautionary disassemble steps if needed? tia, JohnCould be set screws. I'll send you the link to the parts list by PM. Apparently they don't like certain sites here.
Gerry
Gerry, initially, i found it stuck in the neutral position (before attempting running the engine) mind you this sat in the garage for at least two decades.. My step was draining thelower.. I pulled the lower out and everything is in order (no metal and the seals and everything checked fine. after reassembling the lower and refilling lower.. I pulled the plug and sprayed seafoam, cleaned plug and filled proper mixture 50:1 ratio mix.. pulled and it started .. with prop off in a 5 gal. bucket with level water for cooling.. At this point I found the shift handle kinda stuck so I pushed it and it freed without too much effort.. it now feels like it would as it use to engage.. that being it seems connected as I feel it positioning from forward/into neutral and into reverse.. but also can continue a forth position down.. that being the shifter lever point lever end can point down towards the ground. I ordered the rear and front thruster hubs because the rear was broken and the front seemed alttle worn.. these are plastic parts I managed to find online. At this point I'm not sure if I want to attempt power head removal myself and not sure if it feasible to have a marine center do this. If it is just a hundred bucks to have it serviced fine but, rather not spend too much knowing most these parts for this model are discontinued. thanks for helping once again, JohnJohn, Disassembly of the shift handle etc is pretty straight forward but as you will see from this link:
http://www.crowleymarine.com/mercury-outboard/parts/713_7.cfm
the shift shaft which the shift handle is attached to is located within the drive shaft housing so it means removal of the powerhead.
When you rotate the shift handle, does it seem to be moving the shift shaft or does it seem like it is not connected to anything.
Do you have a s/n for the engine?
Gerry
Gerry
oh okay, s/n is 6318559 and no I did not check the lu for shifting.. now it is filled with new gear oil. Meantime, I will also try finding the manual online as you suggested.John;
No, I meant the s/n (serial number) of the engine. I am trying to get a service manual online for it but the site is down for now. Will try later in the day.
I would put the prop back on and see if it is actually going in gear by prop rotation. When you had the LU off, did you happen to check if it was shifting OK by moving the long shift shaft?
Gerry
John;
For future parts ordering, that s/n comes up as a model:
1003203 MERCURY 1983 3.5
Gerry
Yes, I was thinking of one of the set screws where the attachment is made to the long shift shaft which goes down thru the housing to the LU but as you can feel it making gear selection, that wouldn't be it. Still trying to locate a manual and the site is back up. If i find something, I will let you know.
Gerry
Okay Gerry, So far I replaced the thrust forward hub and the other side hub,, also the shifter part mentioned.. I get it to shift now in two positions and realize now that is what it is suppose to do..(either in neutral or Run) The only problem is after re assembling it, I still have no neutral ,, she runs the propeller and idles nice but still no neutral. Now I'm not sure if it is something in the lower .. maybe the shifter rod on the lower has to be further inserted? At the top, I assembled the new part as I found the original and the new part seems to lift and drop the shifter rod but still no neutral.. maybe the lower end needs to be aligned to engage somehow? TIA, JohnExcellent John, knew you would get it. Let me know how it works out in the end.
Good Luck.
Gerry
It's been awhile since I've had one of those little lowers apart, but I seem to recall the shift rod doesn't actually attach to anything inside the unit - it simply slides in through the seal/bearing area. It then acts upon the spring on the propshaft to loosen it and disengage the gear from the propshaft for "neutral". If the shift rod is not deep enough or is worn, it won't hit the tang on the spring to disengage. Or, if the spring itself is worn. Could also be the spring is gummed up or rusted to the hub shaft, thus not allowing it to disengage?
I once straightened a bit of the spring on a similar system used on an Evinrude once to get better engagement. I clamped about a half-inch worth of the spring into a vice and straightened it out, then trimmed it back with a file to get the clearance I needed. Not sure if that would work on the Merc unit - like I said, it's been quite a few years since I've had one apart...
