Im working on a 1980 9.8 horsepower mercury outboard. I am having trouble getting the shifter gear to line up with the shaft gear. what can or do i do to fix this..?
Check the spline on the LU shift shaft, as some have a larger spot on the splines that has to match up with the upper shaft on some modles. They have to be lined up before the LU will go completey together.
Oldman570
