I had bare wires showing from stator and trigger so I removed the flywheel and replaced both of the parts. at some point i rotated the engine when I put the flywheel back on the problem is I can not find a mark on the engine or pointer. I have the engine at TDC #1 piston on compression stroke now all I need to do is put the flywheel on in the correct spot but I cannot find a mark or pointer I have the Mercury service manual and it is no help.
It is Manual pull start flywheel the marks are on the flywheel but not on the engine
Ser # 6010942 I am not sure what year I was told 82. but the recoil is from a 78 confused
50 Hp thunderbolt ignition blue label
4 cylinder
Please help I thought I had this thing fixed and the fish are biting my brother law just caught a 24 lb CAT of the shore
4 cylinder
