79TunnelHullCT
- Mar 24, 2012
- 3
Lost the magnets on my flywheel, the motor cover shows that I have a merc 100hp, it is oil injected with power trim. It has 4 cylinders, the flywheel has what appears to be 261-9007c2. However, I go to look that part number up and it says that part is for a 3 cyl 90 hp. It is unclear wether the 261 is 281, but either way it says 90 hp. Should I try matching a flyhweel to the serial number try to replace it with the same one that was on it?
