barelyfloatin
- Mar 18, 2012
- 3
We were out on the boat todayand the boat was running fine for the first 30 min. We then brought it back to neutral and when we did, it came out of drive hard. At this time the motor began to rev on its own. We shut the motor down, and when we went to restart it again we found it would not start. We did some checking and found the dash was out. We found that when wiggling the wires on the right side of the motor the dash came back on. We got the boat to start again, but it would rev up to 2000 rpm on its own and the motor was missing. Before we took it out on the water we hooked it up to the garden hose and ran it to try to set the rpm before we realized that it had to be done in the water. We also found that the timing was at 12 degress. We brough it back to two degrees. We would like some help trying to figure out why it is missing and revving up on its own.
